Old 04-08-2007, 09:10 AM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Usually once they are set up & working properly they work for life.
You might want to check for clearance around the shift lever in the tunnel or too stiff a shifter boot forcing it out of reverse.
Try unscrewing the ring on the boot & try reverse with it removed.
Craig
