Old 04-10-2007, 07:22 PM
Mark Brye's Avatar
Mark Brye Mark Brye is offline
Cobra Make, Engine: BDR354/FMS392
Default BDR/E36 Suspension Torque Specs from Bentley
FYI, here are some torque specs from my E36 manual. Because the BDR uses E36 suspension/rear end components, I would think they could be related to the BDR... All numbers are ft/lbs. Some of the list may not be applicable to BDR so use caution as these are E36 torque specs. Maybe Jay or Reg could chime in if any of these are in error.
Mark
Front end:
Brake Caliper to steering arm 81ft/lbs
Road wheel to hub 74 (not sure about pin drive hub torque spec)
Stabalizer bar link to strut (M3) 44
Steering arm to strut 78 (replace with new bolt)
Strut assembly to strut tower 16
Control arm ball joint to subframe cross member 62
Control arm ball joint to steering arm 48
Control arm bushing carrier to body 34
stabalizer bar link to control arm 31
Stabilizer bar bushing bracket to subframe cross member 16
Rear end:
Drive axle to front drive flange M8 torx bolt 47, M10 bolt 62
Shock to upper mount 10 (different mount on BDR)
Shock to trailing arm 57
Brake rotor to drive flange 12
Brake caliper to trailing arm 50
Drive axle colar nut to drive flange 184 (Better brake out the beer)
Trailing arm to front bracket 81
Bracket to body 57 (think this is different on BDR)
Trailing arm to upper or lower control arm 81
Upper control arm to final drive carrier 57
Upper control arm to trailing arm 81
Lower control arm to final drive carrier 57
Lower control arm to trailing arm 81
Final drive (diff) carrier to body 57
Final drive carrier front mount 70
Final drive carrier rear mount 57
Brake caliper to brake pad carrier (guide bolt) 22
