Rear end Question
I just got back the rear end (Ford 9") from the machine shop after getting it narrowed. I bolted it into the frame (without axles and differential). Measuring from the flange out to the frame on the right side I get about 2 1/2". On the left side I get 1 5/8". This makes it 7/16" off center. They (the machine shop) said they centered off the outer support arms. It looks like the center supports are off a bit.
Where should I start? How close is "good enough"?
Bryan (B&B) said that most of the frames that were done by Northwest Exotics have needed some correction. Any help from other B&B/NW Exotic owners would be greatly appreciated.
Thanks
