  #27 (permalink)
Old 04-11-2007, 02:34 PM
496fe 496fe is offline
Our dyno runs showed that 750 CFM was plenty. I used the Demon instead of the Holley - use the Holley. I only had about 3 lbs. vacuum at 6,000 RPM, which shows that the 750 was plenty. As you know, for a street car, you always want the smallest carb you can.
BTW, I used a desktop computer program called Dyno2000. After putting in all the variables mutiple times, the calculated horsepower was within 5 Hp. of the actual. Some of those programs are amazing.
