Old 04-11-2007, 02:50 PM
bmwdb10's Avatar
bmwdb10 bmwdb10 is offline
Cobra Make, Engine: Gulf GT40 CAV137, Cobra ERA286
Hey Doug,
What you are describing sounds like a PEM-NUT. It has a serated collar that is pressed into an existing hole. They can be pulled in using a couple of washers and a bolt similar to the way the riv-nut tool works. They should be available in most any size. I use them on some of the equipment I build at work, but only in #8 and #10's. I'll see what I can find for you. Maybe hit up google! Again, the issue is getting at it from the inside. I had my wheels off a couple of days ago, but lucky for me, my suspension is all intact and very tough to see any easy way in there.
Dave
