Thread: Slave cylinder
Old 04-12-2007, 07:55 AM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Originally Posted by Rwillia4
Hawaii,
I am using a hydro pull that works in the stock hole for a clutch cable on the bell housing. It was tapped and a reducing bushing was used to tighten up the hole then a hydro puller fits thru that and attaches to the clutch arm. no other mounting is required.
We looked at this setup, but it seemed to allow the slave to eventually pull apart since it puts the force on the housing instead of the rod end it is designed to pull with at the core of the assembly.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
