Originally Posted by Bob In Ct
You spray and coat the neoprene, the underside of the fender, or both?
Bob
Bob, not sure if your question was directed to me or someone else. I glued the bare neoprene/foam rubber to the inner panels, then coated with BlueMagic Pure Rubber Undercoat (about $10/can at Pep Boys). This stuff will not crack and contains no asphalt. It comes out of the built-in spray nozzle pretty quick, so you have to work your wrists fast to lay down a smooth, dripless coat. I applied up to about 1/4" from the edge of the fender, ensuring that I covered all of the seams and edges. Looks pro.
-Dean
