Thanks Guys, I am going to keep it simple and run a line to the front port 3/8 npt, I will use the rear 1/4 npt to take the
oil pressure(mech) and a fitting for the warning light, and The
oil temp both trans/engine I will use fittings from each respective pan, Tom as a matter of interest what size line are you using with your accusump? I think the acc end is 1/2" npt, Thanks Dave
