  #24 (permalink)
Old 04-14-2007, 04:06 PM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Yetiman - We are ALL in agreement that you need a high rated safety switch regardless of which side you put the darn thing on. But you are missing something here. For example the starter is a very good example of something that can and should be bypassed wired, esp. on a Cobra w/a dash starter switch. Don't forget the function of this switch is for emergency shutoff per the NHRA or or whatever, or can be used as just a simple ignition kill. In a sense it's not about voltage draw so much as it is about how you wire the car and how you plan to use it.
Ron Shockley
