hi mate i would think that it has cracked under stress from jacking , it depends how much your chassis moves when jacking up . think they are around 300 bucks nz ,it is a little tricky fitting new glass remove the side pillars and then undo the screws around the edges ,seperate the pieces and remove glass,you will need new retaining rubber .this is put around the edge of the glass and cut to length. cut off the excess rubber with a razor blade to give a neat finish. be carefull fitting the screws as the screen is chromed brass and will strip threads if too much torque is applied.
