When buying cutoff switches, easy enough to ask for ratings, Use one with a 1000 amp instanteous and at least 180/200 amps continous rating. Anything higher is better.
Don't go lower. Isn't the four post cutoff switch designed to cut power from the battery and the alternator ? A two post works fine for the negative side.
 aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment"....  ...from Will Rogers
