the unit is a 1988 mazda L4 2.2 liter is the one that came on car #260, (advanced auto parts #0728342, this was the number on 9/18/2006, also, the 2.6 liter is a top bleeder version).
My slave failed because of overstroke, according to the Backdraft boys in BB, Fla. They sent me a new one, this ones seal was in bad shape, didn't even use the new one. My failed seal was in better shape. Honed the slave cylinder because of a sever out of alignment of the cylinder to the fork,...this caused the push rod to rub on the bore, plus the over-stroke...caused leakage, draining all fluid overnight. Adjusted the stroke and its been 6 months on the re-aligned slave and honed unit...still good. BTW...stroke adjustment are the nuts on the shaft from the clutch petal to the master cylinder. If you get a replacement, I'd dissassemble it look at the seal to make sure it has a good lip and the bore looks good. Hope this helps.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
