Originally Posted by mjmacqua
Guys,
Just looking for a little insight into what oil most guys are using and what kind of oil pressure you are getting. I have read about zink contents too any opinions.
Looking for type, wt, and pressure at idle warm and under different loads.
I think I may have a problem and want to compare notes.
Mike
Hi Mike, I use Castrol 20W-50 and note 30 or so idle pressure and generally 55-60 range going down the road. Cold idle is higher. Initially I had a mechanical
oil gauge which gave about these same readings, I have since changed to an electric gauge with sensor in the fitting at the driver's side front of the block. I have a remote oil filter and oil cooler setup and have a 20PSI switch out at the remote mount that will turn on a red dash light if oil pressure is ever 20 PSI or lower. It has never come on with the engine running. What are your numbers?
