Thread: LED Lights
Old 04-19-2007, 07:33 AM
sfeakes sfeakes is offline
Since this thread has come back alive, and the origional install instructions from Jay's message board have gone, I've had a lot of PM's asking about the install.
Here are the pic's and wiring diagram, hope it's all obvious.
This is the brake & running light
This is the brake & turn signal
With this you have 3 options for the brake / turn LED cluster that will affect how the unit acts when you have BOTH brake and turn signal on.
  • 1 - No Relay (wire normally) - Brake on full intensity red all the time and turn flash amber (hard to see)
  • 2 - Connect the dotted wire in diagram - Brake on high intensity when turn is not on, and low intensity when turn is on. (sort of flashing bright red to red & amber), this is also quite hard to see.
  • 3 - Don't connect the dotted wire in diagram - Brake flashed from high intensity red to Amber with the turn. (This is the one I use)
Obviously you can use it like stock and just use 2 lights for running & Brake and 2 lights for turn, but I prefer the 4 for brake.
