Thread: Upgrade parts
Old 04-19-2007, 01:43 PM
uncltodd's Avatar
uncltodd uncltodd is offline
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
OK, Skip B brought up the exhaust collector problem. His is build #100, mine is build #139.
I cannot have mods done locally, my guys don't have a clew what you are talking about.
Mine spews exhaust soot into the engine compartment any time the engine is running. It's a direct exhaust leak, under pressure.
The spring-loaded header/sidepipe connectors don't work.
You KNEW that when you built the car and delivered it.
I have not yet seen a "fix" that I can afford or deal with.
I even tried cramming steel wool down into the joint and clamping it with a giant hose clamp. Didn't work.
Historically, BackDraft does not return my Emails or phone calls to Miami.
Fault me if you can, I have the docs.
UT
Eagles soar- but weasels don't get sucked into jet engines.
