Old 04-19-2007, 07:58 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
I have a soft top and side windows, also A/C and heat, makes the car more comfortable, however, I run with the top off, more than I do with it on, I mostly use the top in the winter, it cost over a thousand dollars, so you need to consider that also, mine came from the manufacturer, however most large cities have a company or two that will make one for you, call your local trim shops, also you can search the various Cobra manufacturers web sites
PapaJohn
