Old 04-21-2007, 01:55 AM
Tinker51 Tinker51 is offline
Club Cobra Member
Cobra Make, Engine: SPF
Send a message via AIM to Tinker51
Rob,
No need to remove the axles as I am merely replacing the rear cover which has a crack in it and seeps oil. It looked like I should be able to get the clearance needed by releasing all mounts then supporting and sliding the assembly forward just a couple of inches and thanks for reminding me. I need to stop off at Ford and get some friction modifier.
Bob,
That bolt thing is a damn fine idea! Thanks for the tip!
Lowell,
I saw the breather tube on the new cover so I am aware of it but thanks for the heads up.
Dean,
That piece is very interesting. I will look into it as that is pretty much the reason I am replacing the cover but nowhere near as drastic as the one pictured.
Everyone,
Thanks for your input.
Sam.
We have enough youth. What we need is a fountain of common sense
