Old 04-21-2007, 06:15 PM
1966plus's Avatar
1966plus 1966plus is offline
Default FE and Holley part identification?
Hi Guys,
I'm a newbe to posting on here but have been spectating for a while, but looking for some info about FE and Holley parts ID (I'm UK based so FEs aren't so easy to find over here)
I am building up a Mk.II GT40 replica with an engine being built by Huddart Engine of Crewe. I'd like to know what valve covers the original car carried (I think they were called a "Baldy" cover or something like that) - what else were these fitted to? Also Is the transparent velocity stack a period Holley unit or something special made for the Mk.IIs only?
I see the valve covers don't have a breather. As my engine is also dry-sumped is this likely to be OK or is there another breather system somewhere else I can't see in the photo?
This is my engine spec. by the way
Ford 460ci (7.4l) FE series "Big Block" supplied and built by Huddart Engines, Crewe (UK).
‘May 1970’ block.
Eagle crank and rods.
Custom forged pistons @ 10.5 compression.
Steel damper.
Internal balance.
Edelbrock alloy heads with Victor manifold and Holley carburettor.
MSD distributor and control box with rev limiter.
Edelbrock alloy water pump.
Comp Cams mechanical cam and roller rockers.
Complete AVIAID dry sump kit with 3” oil pan, 4 stage pump with Gilmer drive.
9” oil tank and brackets, original style alloy filler bracket, oil take off, scavenge and pressure lines.
Many thanks guys, I know if there is an answer out there, it can be found here
Craig
