Old 04-22-2007, 12:22 PM
FFRBob FFRBob is offline
Cobra Make, Engine: Factory Five MK3, 390 FE, Toploader
Default Hurst shifter linkage interference
I'm new to the toploader world, so I must be doing something wrong. I setup the hurst shifter linkage per the instructions, but when I try to put the trans in reverse, the threaded reverse bar hits the 1st/2nd arm on the shifting unit. Additionally, When shifting into 2nd, the arm on the shifter has to work its way around the reverse threaded rod. Do I need to trim the 2 or so inches of extra threads on the reverse arm?
