Old 04-22-2007, 04:29 PM
CWizard CWizard is offline
Cobra Make, Engine: SPF, 418 Stroker
Originally Posted by RICK LAKE
....I run crane anti pumpups without any problems. The only thing with them is if you pull the rocker shaft you have to remove all the lifter and get the oil out of the housings. If you don't the valves will stay open and not bleed down. Rick L.
Hey Rick - Are you saying that once the pushrod is removed from these Crane lifters you have to get the oil out of the lifter housings? How do you do that? Disassemble the lifter?
Thanks!
