Give it back to them and make them redo it.
With the housing mounted in the frame it should be centered in such a way that the outer bearing flange on each side of the car is the same distance from an imaginary line down the center of the frame. If it isn't the tires will not fit the same in the wheel wells. Use a tape measure carefully. The pinion IS offset in the center section.
Rick
