Originally Posted by Cobrabill
Ditto CDnus.CFM is NOT the issue here.
Joe-simple stuff first:
Borrow a KNOWN carb.If this cures it then look at:
Verify float level-the littlest piece of crap can cause the biggest headaches.
VERIFY fuel pressure(try another guage)
return line-highly recommended.
CobraBill
Thanks. Tell me more about the return line. How would that be plumbed? We did verify pressure with another gauge and this is another issue. At startup the inline gauge reads 5 lbs. After the car has run a while it will intermittently read as low as zero however the car is idling fine. Is it a bad gauge or bad placement? It is placed at the end of the fuel line run.
Joe
