Old 04-26-2007, 06:48 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make & Engine: ERA 427SC w/427so, ERA GT #2002
Default Bushing fixed; shifting problem
ERA Chas: No problem now, although the steering wheel moving around at high speed can be a bit troublesome at high speed. The bushing wasn't worn, but the press in the housing that retained it was lost. Once fixed in place with Loctite the bushing stays in place and the steering shaft has virtually no play, so all is OK.
On another note, the 3--4 shift is difficult, however all others are smooth . . . ZF transaxle is used. Once the transaxle is warm, the shift is a bit easier, but still a little difficult. I seems like the synchros are ok, so I suspect the problem is with shift likage adjustment. Have you experienced any such problem? If so, got any suggestions on a cure?
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
