Bob,
The rear diff hanger has 3 bolts: two go through the diff cover and the third mounts the hanger to the frame. Isn't there a rubber bushing where the hanger mounts to the frame? I don't recall now without going out and crawling under the car to look. Have you noticed any increase in vibration with the solid front mounts? Any other problems?
Dean,
OK, I get it...thanks. Any problems now that you've changed the pinion angle? Or maybe that mod doesn't change it enough to affect anything?
I really like the idea of the brace, also the solid bushings, if they don't transmit a lot of vibration to the frame.
Thanks,
Lowell
