Brakes
JGC,
Looking at down to earth price calipers Wilwood they have these two calipers which have identical pads, but slightly different area due to number and size of pistons, so I have just added up the sizes which may be wrong but they come out quite close in area?
6 Pot, 1.62, 1.12, 1.12 = 3.86
4 Pot, 1.88, 1.75 = 3.63
This makes a difference with the 6 pot being slightly bigger in piston area of .23, I wonder whether this would actually be noticed if you changed calipers on a test track!!!
Another issue is cooling some say put the largest pad caliper on your car but this can inhibit the rotor/caliper to cool, so I am wondering whether big is better, or just a bit more than you need is good! I have 17" wheels and could fit 14" rotors, but unless it is a skinny rotor the unsprung weight just goes up.
I looked at AP Calipers and could have got some 2nd/hand from an Aussie Supercar, but they are a bit wide for my application, wilwood seem to cater for different needs at a good price better than their more expensive competitors, I cant see the point in spending USD$3500 on an AP or Alcon when a $400 - $600 Wilwood should give good service.
A J. Newton
The 1960's rocked!
