Old 04-28-2007, 09:26 PM
Doug I's Avatar
Doug I Doug I is offline
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
h2 ... when you say 'all lights work' do you mean all the other lights work normally?
When you select a side for the indicators, do the lights come on and stay on with the dash light? Select a side, and see if both the fronr and rear lights come on, or just 1. A blown bulb in a light will usually show as the dash light staying on and not flashing.
If the rear doesn't light it could be the bulb or it could be the base has allowed the bulb to shake loose.
There are several threads covering the rear lights and new bases.
regards
Doug I
Pull a gear .... drop the hammer .... and enjoy the Drive !!
