Old 04-28-2007, 11:36 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Zero lash should be what you got on the first attempt. As you rotate the engine to set others the valve springs will collapse the lifter and give you the impression that its wrong-dont worry its normal. When you first start the engine after setting these there will be some tappet noise until the lifters pump up to there normal run position.
Jac Mac
