Received my tires and wheels yesterday and took the Cobra off the jack stands. Even after turning the adjustment up as far as possible I can't get the front to a reasonable height.
Oil pan is only 1" off the ground. Rear springs seem to strong and front to weak? Big Block engine, B&B 9" rear and tubular front, same OD tires as B&B rec's. Does anyone have a spring rate recommendation for running with a big block?
