Glad you found the problem. I was thinking about the relay after you left.
Originally Posted by h2oman
You guys are awesome! This is why CC is the best club in the world!
Removed the flasher relay, tapped it and pushed it back in, light is out and works like it should. I think however, I will pick up a spare just in case this one is trying to die on me.
Frustraiting to down shift ( saving brakes ) and move the turn signal lever up and down at the same time.
Easier and cheaper to change brake pads than a clutch.
