Need help - lots of it
I have three issues I need help with, build manual hasn't been much help and I am no mechanic:
1) I have the Ididit steering column from B&B, for those that have one installed, how huch of the column is showing between the tapered section and the dash board?
2) Motor mounts, I assume I have to purchase something to weld to the chassis and another mount to bolt to the engine which in turn bolts to the welded chassis mount? I have a 347 stroker if that helps. What do I need to purchase and directions on installation would be a big help.
3) What should I buy for an electric fuel pump? Can you get one with the mounting bracket like in the manual pictures?
I am try to put the push on so I can have the car on the road this summer. Any and all help is greatly appreciated.
Thanks,
Corey Crawley
