Old 04-29-2007, 05:19 PM
D&M2 D&M2 is offline
Cobra Make, Engine: B&B, York 351W (Work in Progress), 07 Shelby GT # 0767, 09 Shelby GT500, 09 Shelby GT500KR #440
I'm still building mine but I can give you some feedback:
1) I went with the Ididit steering column as well. Nothing has been set in stone yet but the mockup that I did had the turn signal stock about an 1.5-2.0" from the dashboard. This may change a little as everything begins to be finalized but that is close.
2) B&B has the motor mounts that can be either bolted or welded in place and are specific to the size engine that you will be using (SB or BB). If you give them a call and let them know what engine you are planning on using, they'll ship them out. There isn't any definite location for the mounts to be installed so you'll need to install the engine/transmission to determine the exact placement.
3) Can't help you at all there as I currently have mechanical fuel pump.
Hope that helps a little.
One other thing that you might want to consider is getting the CD. While it doesn't go into any more build instruction than the manual, it does have a lot of additional pictures of each of the build steps that have been helpful for reference.
