Your Cobra replicas can run as GT-1 cars which are a national class. In the region, they will probably put you in the SPO/SPU 'catch-all' classes. You won't be competitive, but you'll still be mixed with lots of fun cars on track to play with. That is true regardless of which replica make you make - as long as it matches the safety stuff you can run in one of the open classes.
You can also run NASA in the SU categories and, if you wanted to, we could probably get you into the ST classes after seeing a little track performance comparisons.
