Old 05-05-2007, 06:41 PM
stephen low's Avatar
stephen low stephen low is offline
Default Battery lock out switch and rubber trims
Back again with a couple more questions.
Had bought a single contact battery cut off switch but my sparking is suggesting a twin contact jobbie so as to fully cut off engine. A very sensible suggestion seeing as a hot rod mate knew of a bloke burnt to death as his pumps kept pouring fuel out after a crash!
So a twin contact is the go but for racing purposes, what is the requirement for access? I know enough that the location is highlighted by the blue triangle, I believe, or am I wrong?
Where does this need to be and where do you guys generally tend to put the key?
Also thinking about trim rubber for doors and boot, know of a couple of places to try but what am I asking for? Is there a certain sized material to suit each purpose?
slowy
