  #64 (permalink)
Old 05-06-2007, 06:01 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Badger
Lew Ledyard is the brightest guy on this thread. The front of the scoop is a LOW pressure area! Air exits the front of the scoop!
Originally Posted by mr0077
but someone should do a "tuft" test to check that out (tape 1 or 2 inch long pieces of yarn or string onto the leading edge of the scoop and watch it while driving to see which way air was going at the scoop). Obviously having a turkey pan with a hood seal would affect the results due to engine air flow, and I suspect that there are a whole lot of other variables that could affect it...whether the cooling fan was on, is the radiator sealed to the body, is the radiator upright, etc.
With my car, you can see streaks of oil on the underneath side of the scoop going foreward, out the front of the scoop. My take on it is that the air coming through the radiator opening (after warming up) pressurizes the engine compartment, of which a portion exits out the scoop. So, if you nail the throttle, if you don't have a good seal on your turkey pan, not only are you getting low pressure air, but it is warm air as well, both decreasing engine HP. If you seal the turket pan to the scoop, at least you will get cooler air.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
