Guys
Just had a though about
oil temp sender location.
As I'm running remotes to both cooler and
oil filter, could I insert a suitable connector with attachment for the
oil temp sender into one of these lines?
If so would where would it be better to measure from?
I believe the oil leaves the engine to the cooler first, then through the filter next and then back into the engine. So is it better to measure pre or post cooling and then pre or post the filter?
