Old 05-06-2007, 07:19 AM
Rob. Smith Rob. Smith is offline
If you fit a small radiator for the oil, in front or behind the water radiator make sure the air gap between them is about 1.5 " or 40 mm to allow a proper air flow I built a 72 Mustang with air con, oil cooler and radiator with these recommended gaps and had no cooling problems at all....It looked pretty busy but it worked !
Smithy
