Old 05-08-2007, 07:25 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
NAPA part # 3191 - CV Wrench $21.99
NAPA part #3415 - small CV Strap - $1.99
2002 part #'s and pricing...
You will need to "work" the CV clamp to open it for installation, so you don't need to remove the axle's or anything....Note: VERY SHARP EDGES on the clamp...remove old clamp, clean underneath boot and axle surface with q-tips and solvent...burp extra air out of the boot...If I recall, there is a little grove that an edge of the boot locks into....you will see it when you clean it....install the new clamp, tighten, trim, enjoy....I removed the tire when I did mine.....wrecked a nice shirt if I recall correctly leaning up against the wheel hub....antisieze stains...but I digress....clean-up took longer than the repair.....
Let me know if you need any other guidance.....
Good Luck, The eyes of Club Cobra are watching you...
(no pressure)
Blas
