Old 05-09-2007, 11:24 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Braided fuel lines (tank to new tank filter then to fuel pump then to exist hard piping, then braided to carb with pressure gauge - and maybe new braided brake lines, clutch slave cylinder mounting correction, fuel pump power routing with a relay directly from the battery....bleed brakes and clutch while its on a hoist there....top off the turn signal fluid maybe...
