From what i have read, the Mass-Flow system will be your easiest install since you won't have to buy an ECU and wire the whole car as you would with an individual throttle body setup like TWM. The other nice thing is that you won't have to worry about your cam specs since it doesn't really care about it, it works on "air in, fuel to match" type of setup. The hardest part will be running a fuel return line. Its nice too because you can continue to use your roush air cleaner etc.
James
Charlotte, NC
