Hi Dan,
I agree with James, if you are not looking for the stack appearance or weber style EFI then you should check out the data on Mass-flo. I put their system on my SPF and really like it. It is basically a Ford EFI setup uses an A9L computer and the kit includes just everything, wire harness, fasteners, relays, sensors etc. Running fuel lines is not a problem, much easier than I thought it would be, and I was able to convert fuel pump and filter setups almost directly over from my stock part locations. They also offer a fuel line kit which includes all the little pieces needed plus high pressure lines and fittings. Search mass-flo or mass flo or EFI over at ffcobra.com they have a ton of info. This system also "learns" to some extent, will improve with use. I have photos from most every area of my install, pm or email me if you want more info from me, good luck
