Old 05-11-2007, 10:21 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Under load tapping? Sounds suspiciously like a piston pin or rod bearing.Check the valves first like Tim says. With the motor running take a short wooden broom handle ,stick one end in your ear and the other end use like stethoscope and see if you can hear where the noise really is.
