Old 05-14-2007, 06:59 AM
stephen low's Avatar
stephen low stephen low is offline
Thanks guys
Cobber my second post indicates my oil flow pattern, engine to cooler to filter to engine. So you are saying into the line pre cooler perhaps to get the oil temp as it has just lef the engine?
Despite looking at my fitting I'm not inclinde to change my set up at this time ie swap filter and cooler so that the oil is filtered before reaching the cooler. This was in fact the way the std donor car was set up!
Anyway Cobber your suggestion as to where to locate the in line sensor location would be appreciated.
slowy
