With that amount of wear across the width of the bearing it looks like a tolerance problem.
I agree with olddog, the more you mess with it, the more you own the problem.
Someone should measure the rod journals, and make sure the bearing is the right size thickness for it. If it is within spec, then some crud got in there some how and it will likely not go away by itself.
6th generation Texan....
