How did you verify the pump was bad? Only 3-4 psi of pressure will not cause the symptoms you said you had. My own car runs at 3-4 psi on the mechanical pump and 6-7 psi on the electric with no change in how it runs.
Did you ever pull the dist and check the roll pin like I originally suggested?
Sal Mennella
