Old 05-16-2007, 10:46 PM
HI Cobra's Avatar
HI Cobra HI Cobra is offline
I had a similar problem with mine - I used a '85 Lincoln rearend and used
Halibrand wheels. It would almost bottom out on the right side on bridge
joints etc. Found out that shock was bad - but ended up getting some
coil over shocks from Don Scott and put those in - problem solved. I left
the original coil springs in too - the car rides fine for me. The shocks are
adjustible so you can put it where you want it.
Any problems with the front?, it looks close in the picture.
Good luck with it.
Flip
