I'll throw this out there, but you'd better check it's validity before you bank on it. First off, do you have a FE block? If so, it's probably a pre-1974, in which case you could register now through the regular SPCN process. You would need to go to a BAR station every 2 years and they would verify that you have a pre-1974 block and smog you based on that. Pre-1974 doesn't have any smog requirements, other than a PCV valve, so really it would be a formality. Like I said, check with your local BAR station before you take my word on it.
