Old 05-17-2007, 10:23 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Dove rockers on Edlebrock Heads
Hello All,
I would like to know when assembled your Dove rockers with the Edlebrock heads if you followed the instruction sheet for the shim placement.
I just got off of the phone woth Dove and the gentleman explain to me that the Edlebrock heads have a different setup than the other manufactured heads for the rocker arm setup.
The sheet is wrong and does not apply to Edlebrock heads.
Basically,
Looking at the assembly with the roller tip down and the adjustment screw up
You should have a (8) 50ths shims in the kit. Proper assembly should be 1 on right side of the rocker & stand (exhaust rocker), then no shim next to intake rocker, then shim, spool, exhasut rocker, shim, mounting stand, intake rocker, shim, spool,shim, Intake rocker,mounting stand, shim, exhaust rocker, spool, shim, intake rocker, mounting stand, shim exhaust rocker, mounting stand.
ER = EXHAUST ROCKER
IR = INTAKE ROCKER
SP = SPOOL
SH = SHIM
ST = MOUNTING STAND
ST,ER,SH,ST,IR,SH, SP,ER,SH,ST,IR,SH,SP,SH,IR,ST,SH,ER,SP,SH,IR,ST,SH ,ER,ST
I hope you guys understand what I am trying to say.
Does this sound correct
