I am the 3rd owner of my Midstates and it was originally purchased in '87, the 2nd owner actually built the car and the harness he used was from a company called Perfect Performance Products which is now better known as Painless. That harness had a set of schematics but they were not laid out for the Cobra. It was for a generic hot rod. I contacted Painless to see if they had anything better in their archives but we had no success. The harness number is DSM-301. If you can determine if you have the same item as we do, we would be will to provide you with copies of what we have, such that it is. I will tell you that the harness is designed around using a GM steering column wiring design, so if you don't have that column, this most likely won't work for you.
Mike
