Hi Steve,
The door seal for that I used was pinchwed from my local Clark Rubber store. The same seal type will do both the bonnet and the and doors you will need about 6 metres @ 13.95 per Metre. The G Force is very similar to my RMC, so the I expect the same section will fit both. The description of the pinchweld on my receipt is "pinchweld door, escort/gemini/cortina", I have not put a seal around the boot.
Good luck
Ross
