Old 05-21-2007, 08:14 AM
sam-tip sam-tip is offline
Yep. Works fine for first ten minutes then when it gets hot voltage will varry. I took it in to get regulator replace today. Still want to upgrade harness to something better if possible.
I wonder if the blue wire that activates the alternator is getting bad voltage and then causing problems with the alternator.
